I am using a Pioneer DDJ-SB3, udpated firmware and drivers, Windows 10. My Audio outputs are Channels 1 & 2 for master and Channels 3 & 4 for the headphones - both using DDJ-SB3 (WASAPI). When I have the master button on, and cue 1 and cue 2, if the fader is all the way to the left side, I cant preview/hear the audio in cue 2 unless the fader is to the right side and same thing if the slider is all the way to right side AND the master button is on, I cannot hear hear the left deck/cue 1 audio. If I turn the master button off, I can hear cue 1 and cue 2 in my headphones regardless of what side the fader is on. Is there a way to fix this? I should be able to to preview cue 1 and cue 2 regardless if the master button is turned on or not. Please assist.
geposted Tue 16 Aug 22 @ 1:35 pm
A Picture of your sound card setup may help others to figure this out for you.
geposted Tue 16 Aug 22 @ 11:57 pm
try turning on exclusive audio access
also make sure it is not set to your system default sound card
geposted Wed 17 Aug 22 @ 12:16 am
I Think he might have them all pushed at the same time and they won't sound right that way.
Only use one button at a time. If your crossfader is on 1 and its playing, then you should be able to que 2 with crossfader on 1.
geposted Wed 17 Aug 22 @ 12:23 am
