Why does KEY (master tempo) affect the scratch sound, it's not logical to imitation vinyl. The scratch sound on real vinyl does not depend on the pitch.
geposted Fri 26 Aug 22 @ 5:41 am
To clarify: the button on controller is the keylock (MT is displayed on the skin)
geposted Fri 26 Aug 22 @ 10:36 am
A real turntable doesn't have keylock
geposted Fri 26 Aug 22 @ 4:48 pm
wickedmix yes. So what?
geposted Fri 26 Aug 22 @ 11:57 pm
@Wickedmix, some real turntables do have key lock.
To answer op, though. If you were previously a Serato user, Serato smart disables key lock when you’re scratching. That’s why you’ll notice a slight delay for really tiny scribbles if keylock is engaged.
I personally like having the difference in sound with keylock on or off in VDJ. Just one more way to manipulate the sound. My advice, map the keylock to a button close to your thumb. In my case, the flux button on my z2 is mapped to keylock.
geposted Sat 27 Aug 22 @ 12:05 am
anto.lonso86
For the user, at least you need to make a choice in the settings, how does KEY affect on scratch.
But by default, it should not affect the sound, because scratch implies manual sound control.
User must understand exactly that his hand will always have the same sound when scratching, regardless of the tonality. Like on real vinyl
geposted Sat 27 Aug 22 @ 1:07 am
and in the skin you need to split so that the KEY or MT is reflected
geposted Sun 28 Aug 22 @ 2:34 am
