Field 1 & 2 are quite convenient to input data from pull-down list. Trying to use these fields, and renamed there fieldname to Venue and Situation.
I'm also testing to use G-drive to listen and update songs' tags from Office computer (main computer /database at home).
Here are the process:
Home Main Computer:
Testing folder at Home computer D:\...\drv-N, subst as N: drive, VDJ only see it as N: drive.
Use G-Drive to backup / sync D:\...\drv-N to G-drive (computer: Dell-15)
Use G-Drive to backup / sync My Documents\Virtual DJ to G-drive (computer: Dell-15)
At Office Computer:
From G-drive ; other computer ; Dell-15 ; drv-N, subst as N: drive, successful. VDJ only see it as N: drive.
From G-drive ; other computer ; Dell-15 ; Virtual DJ, copied root files *.xml settings.* ,etc.
Run VDJ at Office Computer
Can see N: drive and all standard mp3 tags.
Can see selections from pull down lists of prelisten info tab.
Problem:
However, all songs' contents from Field 1 & Field 2 are missing.
I think the database from N: drive are ok.
So I'm thinking maybe the contents of Filed 1 & 2 are stored differently somewhere.
Kindly assist.
Many thanks
Best Regards,
Richard Artimix.
Home Main Computer:
At Office Computer:
Problem:
Kindly assist.
Many thanks
Best Regards,
Richard Artimix.
geposted Mon 29 Aug 22 @ 2:23 am
After some checking, I think the pull down lists are not from home computer but just from Office computer.
Problem (updated) :
All songs' contents from user Field 1 & Field 2 are missing.
User Field 1 & 2 pull down list (in info tab) are not updated as well.
Thanks again
Richard Artimix
Problem (updated) :
Thanks again
Richard Artimix
geposted Mon 29 Aug 22 @ 5:34 am
