Topic: Does this track exist in this playlist?
Is there a command to do the following?
I have marked a track and want to add it to a playlist, but first I want to check whether this track is already in this playlist?
geposted Fri 23 Sep 22 @ 9:31 am
A custom button assigned to search_playlists will show which playlists the song is in.
If you show the 'In playlist' column in the browser info tab, you can also click it, select 'Add to playlist...'
If the song is already in the playlist, a check mark will be shown
You can use the command search_playlists on the highlighted track to see a list of the playlists it exists in
Hi thanks for the replies, I'm all familiar with the functions of Search_playlists, but this
is not what i need!
I create a playlist in Automix and already have a lot of titles in it, if I want to add a new title I want to see first whether this title is already in the list or not, before I add the title.
Just go ahead and ADD anything, then select in the option, "Remove Duplicate"
