Hi, is there any way to find out VDJScript that a deck has a ColorFX effects window open?
geposted Wed 28 Sep 22 @ 9:35 am
For the deck you wish to query, use:
to open or close the GUI
OR to find out if a deck has a ColorFX GUI window open (what you asked):
VDJ ver 7151
effect_show_gui 'colorfx'
deck 2 effect_show_gui 'colorfx' ? (Action, if deck2 ColorFX GUI is open) : (Action, if deck 2 ColorFX GUI is closed)
VDJ ver 7151
geposted Wed 28 Sep 22 @ 10:06 am
Thank you for your response.
I'm talking about a popup window
It's a colorFX effect selection window
filter_selectcolorfx
geposted Wed 28 Sep 22 @ 12:41 pm
effect_select colorfx
geposted Wed 28 Sep 22 @ 1:54 pm
Solved. Thanks
effect_select 'colorfx' ? (window visible) : (window hide)
geposted Wed 28 Sep 22 @ 4:03 pm
