Hello
I am using the skin Project X 2021 Pro by Touchdan which works almost perfect for me.
Since I am using a separate quite small screen with my Pioneer XDJ-XZ and a ”embedded” NUC pc the size of the text on the decks are quite small and I wonder if there is a way to increase the size just like is possible on the browser?
Or perhaps editable in skinfile?
Thanks!
Thanks!
geposted Tue 04 Oct 22 @ 4:50 pm
