Have you already noticed that the insert function does not work anymore?!
geposted Sun 09 Oct 22 @ 12:13 pm
Where exactly are you trying to paste things?
Just tried, but seems to work fine here in the browser search field for example, either using CTRL+V or right-click paste.
geposted Tue 11 Oct 22 @ 10:01 am
I wanted to create a custom button with the following script (I copied the script here from the forum but it can't be pasted)
repeat_start 'colorTracks' ? on & repeat_stop 'colorTracks' : off & browser_window "songs" & browser_scroll "top" & repeat_start 'colorTracks' 100ms & ( get_browsed_song 'harmonic' & param_cast 'text' &
param_equal '01A' ? browsed_song color '#70ECD4' :
param_equal '01B' ? browsed_song color '#00EDC9' :
param_equal '02A' ? browsed_song color '#92F0A4' :
param_equal '02B' ? browsed_song color '#27EC82' :
param_equal '03A' ? browsed_song color '#B1EE86' :
param_equal '03B' ? browsed_song color '#85ED4E' :
param_equal '04A' ? browsed_song color '#E6E0A2' :
param_equal '04B' ? browsed_song color '#E0C86E' :
param_equal '05A' ? browsed_song color '#FEC8AC' :
param_equal '05B' ? browsed_song color '#FFA279' :
param_equal '06A' ? browsed_song color '#FFB3BF' :
param_equal '06B' ? browsed_song color '#FF8C93' :
param_equal '07A' ? browsed_song color '#FFB4D2' :
param_equal '07B' ? browsed_song color '#FF85B4' :
param_equal '08A' ? browsed_song color '#EBB7F9' :
param_equal '08B' ? browsed_song color '#F087D9' :
param_equal '09A' ? browsed_song color '#E7B6F8' :
param_equal '09B' ? browsed_song color '#CE93FF' :
param_equal '10A' ? browsed_song color '#C0CEFB' :
param_equal '10B' ? browsed_song color '#A1B9FF' :
param_equal '11A' ? browsed_song color '#94E5F8' :
param_equal '11B' ? browsed_song color '#3ED2F8' :
param_equal '12A' ? browsed_song color '#50EBF0' :
param_equal '12B' ? browsed_song color '#01EDED' : )
& browser_scroll 'bottom' ? repeat_stop 'colorTracks' : browser_scroll +1
geposted Tue 11 Oct 22 @ 12:13 pm
Tried to reproduce the issue.
I can easily paste your script into a custom button.
And strange that you cannot paste, for some reason.
(and appears that your system's copy and paste is working well well, since you were able to copy and paste the script from another thread.)
(have not tested if it works to color code tracks to the key color)
win10
vdj 7166
win10
vdj 7166
geposted Tue 11 Oct 22 @ 3:20 pm
Ctrl+v works.
The Right Click Context Menu doesn't work!
Custum button
Setting/Maping
b7166 Windows
Custum button
Setting/Maping
b7166 Windows
geposted Tue 11 Oct 22 @ 3:45 pm
Edit it's only when the script longer than 1024 lettes/sings.
geposted Tue 11 Oct 22 @ 3:52 pm
The right click paste funktion is work now.
Have VDJ fixed this?
In the LOG doesn't read anything.
geposted Sun 16 Oct 22 @ 11:57 am
Increased the limit a little, since indeed some scripts are getting large :p
geposted Sun 16 Oct 22 @ 2:15 pm
