Topic: broadcast not working after update
DO NOT UPDATE VDJ YOU WONT BE ABLE TO BROADCAST TO ANYTHING IF IT WORK BEFORE>> SUPPORT JUST GIVES YOU NOTHING..
geposted Tue 11 Oct 22 @ 9:04 pm
I've tested Facebook, Twitch, YouTube,..and was able to connect and stream to all of them using the current EA build update.
if you're going to make a post about something not working or that you feel is a 'bug' or other issue.. please give real details that the dev's can look at. no one can fix an issue or help you if you have a specific issue, if they don't know what the issue is aside from one thing not working on one person's computer.
thanks i got it...
Same issue here. I tried to 2 different servers on both my laptops i updated and they both shut down. I tried use my cellphone to connect to same server and it works. I tried cell phone on wifi network the laptops are on and it connects. Yeah something happened after update.
could the bug be with a custom rtmp?
user24671917 wrote :
thanks i got it...
i had issues using a custom rtmp, so went back to b7151 and mines connects now as showm
I ran into this today when I tried streaming to Twitch. VDJ (7168) crashed as soon as I hit the broadcast button.
Reverted to previous build and it was fine. GTX1650 graphics if it's related.
Is safeVideoDecode option enabled for you?
Yes it is enabled.
Can you try turning it off? It shouldn't be necessary for 1650
Next stream is tomorrow so I will try then.
Turning off safeVideoDecode did the trick. Thanks Adion.
Thanks, will investigate further why it doesn't work with safeVideoDecode on (since it is needed for some older gpu's)
