Topic: How to use the pitch sliders for changing pitch without BMP?
Hello,
I know that by activating the "MT" button (which I believe is activated by default) you can change the BMP without affecting the pitch (I believe some talk about key here, but as a musician I prefer to call it pitch), i.e. enabling the time-stretching. However, I would like quite the opposite: keeping the BPM constant, but using the sliders to quickly pitch-shift up and down. Any ideas/alternatives are welcome!
geposted Tue 01 Nov 22 @ 8:59 am
There is no slider for this. However there are dedicated buttons and menus.
Just use KEY change.
yes, I know, but this is less fun for quickly/crazy effects.
Alternatively, I can use the Pitch FX of course, but this is not the same algorithm I suppose.
You can use "key_smooth" on a slider then..
Ah that seems a good idea... you mean to assign some custom slider with this parameter? Will give it a try - thanks!
