Hi, I found a posting that explains that it is possible to sort by 2 columns by clicking on the column heads after another. The problem ist, that if I change to another filter folder, I have to do this again all the time.
I cannot find a way to tell a filter folder to sort by 2 columns. Like "sort by BPM and sort by Key".
Am I missing something or is there a workaround?
Thanks!
Thanks!
geposted Wed 30 Nov 22 @ 12:20 pm
settings keepSortOrder yes ?
geposted Wed 30 Nov 22 @ 12:28 pm
