Topic: Prime 4 help.
Hi, yesterday channel 2 fader on my Prime 4 broke. Have a gig today. Is there a way to map Channel 4 fader to act as Channel 2? If I tried maps it as Deck 2 volume, all faders act like channel 2 fader.
Thank you, Tomas
geposted Sat 03 Dec 22 @ 1:36 pm
You could still use Deck 4 as your Right channel and mix CH4/Deck 4 with whatever Left channel/Deck u want.
geposted Sat 03 Dec 22 @ 4:08 pm
djmilaPRO InfinityMember since 2008
Dj dad
Yeah that’s true, but must have 4 deck skin on my MacBook 14 inch and then is there not much space for browser
geposted Sat 03 Dec 22 @ 4:30 pm
The default 2 Decks skin can handle Left/right logic just fine
geposted Sat 03 Dec 22 @ 4:45 pm
Thanks worked that way. Just to let you know, default performance skin do not swap decks. Don’t know if this is an issue or not. Default Pro skin swap decks fine. Thanks for your help DJDad.
Ordered faders yesterday so will replace them this week.
geposted Sun 04 Dec 22 @ 3:53 pm
