Topic: STEMS2.0 runs on Radeon 680M?
bubblebPRO InfinityMember since 2013
Does STEMS2.0 work with Ryzen7's built-in GPU "Radeon M680"?
In the benchmarks, it is about the same performance as the GTX1050.
geposted Sat 03 Dec 22 @ 3:36 pm
If you have this CPU, you can try by disabling 'Don't use gpu' in the stemsFix option.
Not sure how fast it will be though.
geposted Sat 03 Dec 22 @ 3:38 pm
Thank you very much.
I am considering purchasing a new laptop and am looking for a model that works with STEMS 2.0.
geposted Sat 03 Dec 22 @ 3:44 pm
I’m also interested in knowing the capabilities of using this cpu with igpu processing the stems, so you’r saying it’s not possible to use the igpu to process stems in real time??
geposted Fri 09 Dec 22 @ 11:52 pm
Hiciste la prueba como te fue alguien sabe que tal se mueve con una GTX 1650 ??
geposted Sat 10 Dec 22 @ 7:18 am
