Topic: new stem 2.0 bug
after turning off automatic stem preparation and only using reduced quality it is still digging into my files and forcing stem separation folder to be loaded with entire library. removing all files in separation folder has cause performance issues as loading any song onto a deck causes vdj to dig back into all files from one song loading. Ironically the song loaded onto the deck is even one the files that get scanned into folder nor are they songs from the playlist I selected.
geposted Wed 14 Dec 22 @ 3:06 am
