My software is freezing after the update but the Playlist is playing ok. I just can't use the software due to it froze.
I have to close it on management the start it all over then it refreeze.
geposted Wed 14 Dec 22 @ 10:11 pm
I have the same issue. The sound keeps playing, VDJ is frozen, Controller is locked. The computer still works.
I have to force close VDJ and re-launch.
Once open VDJ has forgotten where it was and I have to reload any playlist, mix, etc.
Virtual DJ v2023 b7360
Processor 12th Gen Intel(R) Core(TM) i7-12700H 2.30 GHz
Installed RAM 32.0 GB (31.7 GB usable)
System type 64-bit operating system, x64-based processor
Edition Windows 11 Pro
Version 22H2
OS build 22621.963
Only have an issue with VDJ, all other software works as it should.
Version 22H2
OS build 22621.963
geposted Sun 25 Dec 22 @ 4:14 pm
