hi all how do you set deck 1 to pitch range 6% ...deck 2 to say 10% or diffrent pitch range
so they dont change same on both decks using pioneer ddj 400
but when i change pitch range on deck 1 to 10% from 6% it changes for both decks and i dont want this ....i want it so i can change diffrent pitch ranges for each deck ?
geposted Sat 17 Dec 22 @ 8:09 am
Let me know if you got an answer on this, I also dont see how to change the tempo in the software, I am currently stuck at 8% +/-
geposted Wed 15 Feb 23 @ 3:34 pm
Trying to think of a scenario where you would need to have a different pitch ranges on different decks?
I'm confident that this isn't a feature on other DJ software too.
geposted Wed 15 Feb 23 @ 4:59 pm
@MRDJMEL
possibly but also only possibly -----> for scratching
and
"Let me know if you got an answer on this, I also dont see how to change the tempo in the software, I am currently stuck at 8% +/-"
see ----->
https://de.virtualdj.com/manuals/virtualdj/interface/decks/deckbasics.html
section ""Pro" number 6
and
see ----->
geposted Wed 15 Feb 23 @ 9:17 pm
Hi,
You will need to do a "Manual Mapping" on each deck, using the Virtual DJ coding.
In order to change the pitch from 6% > 10% you will need to change the map setting manually again.
It is NOT POSSIBLE to do this when you are doing a live gig though, as it takes 3+ minutes to enter
the code, depending how many decs you are using.
geposted Thu 16 Feb 23 @ 7:27 am
