BUILD 7403 (2023-01-09)
-Pioneer DDJ-FLX4 support
-Akai LPD8 MKII support
-Fix automix editor prelisten distortion when song loaded on deck
-New "Echo Out" mix fx
-Multiple stems fx can be used at the same time
-Smart fader, use smart_fader on a custom button to enable
-Fix lottery plugin not loading some jpg correctly on windows 64-bit
-fix using 2 video effects at the same time on sampler causing transparency to be lost
Would love to know more about this NEW feature/addition. "Echo Out" mix fx
geposted Thu 12 Jan 23 @ 8:38 pm
geposted Thu 12 Jan 23 @ 8:46 pm
it's a crossfader fx as found on essentials skin or effect_mixfx script
it's just echo that doesn't get any strength until the xf is closed to the channel
geposted Thu 12 Jan 23 @ 8:50 pm
Thanks !
geposted Thu 12 Jan 23 @ 9:13 pm
