I have a desktop with 32gb ram an nvidia etc 3070 ti graphics card, an AMD 9 7900 4.7ghz 12 core cpu and 970 evo plus 2tb ssd with plenty of fans and windows 10. While playing one track and loading a new track in another deck during the time the new track is computing the sound over the speakers has a crackling sound until the new track computing,about 7 seconds. The pc is using Gpu for the task and I have switch it to cpu which does stop cracking but slows down process to about 40 seconds give or depending on track. Is there any tweak’s that can be done to correct this.
geposted Sat 14 Jan 23 @ 2:13 pm
Are you just using the onboard audio from the computer? No controller, no external audio interface?
geposted Sat 14 Jan 23 @ 2:21 pm
No I’m using my denon x1850 mixer, I also have the same issue with my Rev 7 controller. I have a MacBook Pro 2021 with M1 and it works fine. A little slower doing real time stems but no crackling
geposted Fri 03 Feb 23 @ 11:11 am
