I was just checking to see if the glitching had been fixed when using the pitch effect on vocal stems.
It hasn't, but in the process I noticed that the pitch colorfx doesn't work at all. The vocal one does, reverb doesn't etc. etc.
geposted Sat 14 Jan 23 @ 5:06 pm
Hmm... Mine seems to work ok
What am I missing?
What am I missing?
geposted Sat 14 Jan 23 @ 5:46 pm
It seems to be linked to using StemsFX. If I just open VDJ and use a ColorFX, they work.
If however I use the stems pad page and enable StemsFX vocal and the pitch effect plugin, when I then try ColorFX, that's when the issue occurs.
geposted Sat 14 Jan 23 @ 6:01 pm
Groovin, I tested your specific issue and you are right, same here..
geposted Sat 14 Jan 23 @ 8:35 pm
