Is it possible to map a single knob for an FX parameter, that will change the value on 4 decks at once?
geposted Tue 17 Jan 23 @ 8:23 am
set in front of your script "deck all"
for example:
first fx slot, 2nd slider
for example:
deck all effect_slider 1 2
geposted Tue 17 Jan 23 @ 8:36 am
Besten Dank / Thank you so much :-)
for example:
for example:
geposted Tue 17 Jan 23 @ 6:13 pm
