hi guys,
How can I stop this really annoying thing happening after every forced WIN update? I have many pro accounts in various venues and I'm consistently being logged out and in some, loss of config after win updates. The Djs don't have the passwords so this represents a massive PIA!
Remember me is checked in all.
Thanks in advance for any help.
Mike
Mike
geposted Tue 17 Jan 23 @ 2:02 pm
Hi guys,
No ideas on this update signout problem?
mike
mike
geposted Thu 02 Mar 23 @ 11:57 am
If you're using the same account on multiple machines, then that's how software is designed to work.
According to EULA you're allowed to log in at 2 systems at the same time provided that you are the single user of them (one for main operation and one for backup)
If you have many different acounts then you should make sure that each account is not used more than twice. Normally it should be more than once, but we don't examine the "legal" issues right now. Only the technical ones.
PS: Windows updates should not matter. Unless you use some shady way to configure multiple machines with one license.
geposted Thu 02 Mar 23 @ 12:07 pm
Apologies, I did not see this, every machine has it's own Pro license.
geposted Sat 17 Jun 23 @ 8:55 am
