Topic: Database max files or size?
Just trying to repair my database in a way, have tried to reinstalled it all, but it seems stuck to only find 138000 files on my 16TB disk with over 1mill tracks. Any clue? I use the command "isscanned=0 or isscanned=1" with recursive folder reading, but stuck with 138000 files.
edit: Seems i have the right database anyway, when I hit "A" on the search string, I get over 1mill results.
But still interested if there is some limit anywhere, maybe with the isscanned=0 or isscanned=1 command?
geposted Thu 19 Jan 23 @ 2:55 pm
Is the scope of your filter set to the entire database?
If you set it to recursive, it will depend on where you put the filter folder.
geposted Thu 19 Jan 23 @ 4:11 pm
Yes i have a filter folder located in my root folder where my music is located. I have also tried directly in the root of my D: disk where my music folder is (nothing else), still just around 138000 files show up... same with both 32 and 64 bit version. And also after total removing and reinstalling of both versions and deleting virtual dj folder inside (~c://appdata) .
geposted Thu 19 Jan 23 @ 6:32 pm
