Topic: Stems + FX VOC ECHO = skip?
When I use Stems + FX and VOC ECHO once the echo out is done when I unclick the pad the song makes a skip like noise and then continues where song is.
CDJ V2023 b7388
The computer is XPS 17
Processor 12th Gen Intel(R) Core(TM) i7-12700H 2.30 GHz
Installed RAM 64.0 GB (61.7 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch Touch support with 10 touch points
Windows Pro 11
Any topic advice is greatly appreciated.
Thanks!
geposted Fri 20 Jan 23 @ 2:19 am
I'm pretty much having the same issues.
It causes like a brief audio glitch when turning off the stem FX
CPU i9 9900x
GPU RTX 2080ti
32gb Ram.
Only seems to be when the controller is on, which is a DDJ-RZX.
geposted Sat 21 Jan 23 @ 11:21 am
Did you try Early Access build 7403?
geposted Sat 21 Jan 23 @ 11:27 am
Yes-its the version I have at the moment.
I've been having this issue since stems V1.
I'm not sure whether it could be related to USB as I have to use USB2 ports with the RZX otherwise I loose my screens at random times with USB3.
If I turn the RZX off and just use the XP1 and mouse I have no issues at all.
(edit) Just tried USB3 of curiosity, but the issue is still there.
geposted Sat 21 Jan 23 @ 11:33 am
I will test off USB and see if the problem still happens.
I did a test on the DDJ-SR , I get the glitch on the only two pads:
STEMS+FX
Voc Echo and Voc Reverb
I do not get the glitch on:
STEMS+FX
Instr BtGrid or Instr Echo
I have tried everything on my end. Noting will fix it that I have control of.
I will try off the controller in the next few days and report back.
Thanks all!
geposted Sun 22 Jan 23 @ 1:17 am
I have also noticed that I get it on the pad page Stems 2.0 on certain tracks when cycling through the STEMS FX button returning to Stems FX, but only after an effect has been applied and leaving time for the effect to finish.
geposted Sun 22 Jan 23 @ 9:23 am
geposted Sun 22 Jan 23 @ 4:51 pm
Sorry I did not see your post.
Hopefully we can get this looked at now that more are talking about it here.
I do not use early access so I can not report on it, maybe someone else can??
Thanks
geposted Sun 22 Jan 23 @ 4:55 pm
Ok, When using a mixer
I tried DDJSR, DJ2GO2, and DDJ1000.
I get the audio glitch.
When no controller is plugged in, just headphones or laptop speakers, I do not get the glitch.
If I did hear anything, it was just the Voc Echo switching off, and the level of the track not being equal to the volume would sound off. Seems like when Voc Echo is on the track volume might dip a little? (anyone else notice this?)
Hope this helps devs fix any issues.
Thanks!
geposted Tue 24 Jan 23 @ 5:03 pm
djlazypHome userMember since 2011
Getting the same thing running MacBook Pro m2 max and 2 cdj 3000s with djm 900nxs2. Glitching and cutting out when activating or deactivating stems fx. I’ve tried with my ddj rz and it does the same thing. It Doesn’t do it in laptop mode nothing connected only when hooked up to equipment. Seems to be stems related in some way.
geposted Thu 16 Feb 23 @ 11:09 pm
The latest EA update (b7462) fixes the audio glitch for me. A big thank you to the development team.
geposted Sat 18 Feb 23 @ 11:08 am
this is happening to me on latest version ...
did anyone find a solution? I knew I wasn't bugging out. it randomly changed and I cant get it back. driving me mad. using rane 4
geposted Sat 21 Oct 23 @ 1:06 am
still got this issue. did anyone find a fix
geposted Wed 25 Oct 23 @ 12:27 pm
