Sometimes when I change the song title in iTunes, the song title in VirtualDJ does not change.
For example, if I add (memo) in iTunes, such as "song title (memo)", it remains "song title" in VirtualDJ and does not change.
Is there a workaround for this?
geposted Fri 20 Jan 23 @ 2:31 pm
No, not if they have already been loaded into the VDJ database
Then you have to tell VDJ to reload the tags for the tracks
The best workaround is of course to use the VDJ tag editor instead, and then set it to write the tags using the setTagsAuto setting
Another way it to load the tags individually from the files in the tag editor (the little arrow below the field)
geposted Fri 20 Jan 23 @ 2:50 pm
Thank you very much.
There was a small problem on the iTunes side (cause unknown).
And in VirtualDJ, I reloaded the tags and by hovering the mouse cursor over the song title, it updated.
geposted Fri 20 Jan 23 @ 4:10 pm
