Is there a way to hide or a setting that will remove the remix field from the song window when they are on deck. It drives me nuts. I think a lot of us have our songs named with the remix already in the title, so, for me at least, all it accomplishes is to scroll the song back and forth so I can't see what I want to see in the window.
geposted Wed 25 Jan 23 @ 2:43 am
I answered you in the FB group
geposted Wed 25 Jan 23 @ 8:45 am
Why is a question asked in the forum, NOT answered in the forum?
Or at least a paste here also.
Its bad enough when topics are across other threads.. to follow.
geposted Wed 25 Jan 23 @ 12:11 pm
Give us an example (with a screenshot of Tag Editor) for a Track where the Remix shows up double in Deck area of the skin.
Just an assumption but for the majority not correct. Unless you are talking about filenames and not Database Title fields
In your case you could ..
- Click on the Title on the Deck and prevent from scrolling
- Edit the skin XML file and remove the Remix text (if u want further info, tell us which skin you are using to provide detailed instructions)
DJNeilSFLA wrote :
... I think a lot of us have our songs named with the remix already in the title
geposted Wed 25 Jan 23 @ 12:18 pm
Thank you so much for your answer How do you turn off scroll in the window? Excuse my ignorance
geposted Thu 26 Jan 23 @ 2:07 am
Sorry, you are right of course - it was just me being lazy because I just tried to answer it in the FB group where i first saw the question :)
Here is what I wrote:
Ok, so you have the info twice in the tags ,which is why it's shown twice
You can edit the skin.
As a test I removed the 4 lines with "get_remix_after_title" in lineno 1937, 1951, 2877 and 2891 in the pro.xml file (because I use the pro layout), selected the default (edit) skin that then appears, and now I don't get the remix tag shown in the title area:
You should be able to do something similar
geposted Thu 26 Jan 23 @ 10:19 am
By default the option cleanTagsInDeckDisplay is on, which will prevent the remix to be shown twice if it is both in the title and remix field.
geposted Thu 26 Jan 23 @ 10:26 am
