suggestions on hardware specifications
current laptop below>
ASUS zenbook UX8402za windows 11 22h2 home 12th gen i9-12900h 2.50 Ghz 32 gb RAM, nvidia geforce RTX 3050ti. VDJ2023 b7388. Rane ONE ASIO 1.0.1 .
i continue to receive random audio cracks distortion static.
issues with RTX3050ti, windows 11, ASUS.
need a replacement that is windows OS, RTX series and solid real world performance.
ASUS or HP ?
ASUS or HP ?
geposted Mon 30 Jan 23 @ 6:54 am
How much VRAM for nvidia geforce RTX 3050 TI? 4Go of GDDR6 or more?
Is it a dual video cards? Do you also have Intel® Iris Xe Graphics on it?
geposted Mon 30 Jan 23 @ 7:27 am
Make sure the Graphics card has at least 6GB of whatever they're calling it now (GDDR5X, VRAM, VIDEO MEMORY ETC). 8GB or more is better though
geposted Mon 30 Jan 23 @ 9:15 am
The Most 3050 only have 4gb and this are Not enough for Stems 2.0
Look for a 3060 or wait for the next Generation RTX with more than 4gb vram
geposted Mon 30 Jan 23 @ 11:51 am
Thanks for suggestions
Yes I have the dual GPU Intel Iris XE with the NVIDIA RTX 3050ti. And I attempted the setting of skin runs on low GPU , so Intel iris card runs at 50% with VDJ.
The 2023 RTX 4000series is what I’m hoping will avoid any audio glitches . Unless there is an ASUS -NVIDIA-windows structure problem , they refuse to address.
geposted Mon 30 Jan 23 @ 3:24 pm
I tested a couple of ASUS laptops and found they had really bad audio latency.
Can't see the RTX 4xxx being much better than the RTX3xxx cards. Same architecture and probably the same drivers. It's not the graphics card that causes audio problems anyway.
geposted Mon 30 Jan 23 @ 3:29 pm
Yes, it’s a disappointment, I guess HP series again.
My 2016 HP spectre has no VDJ problems. But stuck at windows 10 and NVIDIA mx920 is outdated.
geposted Mon 30 Jan 23 @ 4:03 pm
