Does this filter read the file tag or check on the web using song title?
geposted Tue 31 Jan 23 @ 4:44 pm
tags, look up would take FAR too long
geposted Tue 31 Jan 23 @ 4:48 pm
ok thanks...
geposted Tue 31 Jan 23 @ 4:49 pm
Just disregard that VDJ can automatically tag mp3 with missing information from Disco G....whoa!
geposted Tue 31 Jan 23 @ 5:57 pm
A little tip for you. If discogs is not showing then delete the year, THEN write tag, THEN try again. This is great for those compilation CDs with the year of the compilation rather than the actual release year of the tune. Did you know that you can highlight a bunch of tunes and set it away automatically! Your welcome :-)
geposted Tue 31 Jan 23 @ 6:06 pm
@DJLes actually I tried that feature with my 6K songs without "Year" tagged...and it didnt go well...actually it seems they remained without year...try to work on in a little more...
geposted Thu 02 Feb 23 @ 5:20 pm
