I have a feeling I'm missing something simple here...
When I load a song, the stems are calculated... no problem. I have a folder set up to save stems to... no problem. But, when I reload a song that has already had stems calculated, it recalculates the stems every time. What am I missing?
geposted Fri 03 Feb 23 @ 5:04 pm
set option "stemsSavedStems" to Automatic
Just be aware that will create a stems file on the hard drive several times the size of the original (if mp3) so be aware of space.
geposted Fri 03 Feb 23 @ 5:12 pm
Thanks for the reply. I checked my settings and I have that setting correct. I also confirmed that the folder I designated at the location for saving stems is correct (path is good, permissions are good). But stems are still recalculated with each song load. Any other thoughts?
geposted Mon 20 Feb 23 @ 3:37 am
Which Build of VirtualDJ are you using ?
What is your computer's OS ?
VDJ doesnt create sub-folders in the path you have defined ? If does, no Tracks there ?
Your Stems settings look like this ?
![](/img/375925/39774/StemsSaved.png)
geposted Mon 20 Feb 23 @ 4:39 pm
