How does that work, my RB database is on drive F:/PIONEER
I entered it in VirtualDJ but I don't see any RB playlists in VirtualDJ?
And I can't manually see the lists anywhere either!
BTW, I only need Rekordbox because VirtualDJ still doesn't have the "Related Tracks" feature
geposted Tue 07 Feb 23 @ 10:09 am
It's the path to the master.db file (Rekordbox database) , which by default is located at .. C:\Users\USerNameAppData\Roaming\Pioneer\rekordbox
IF not located to the default folder, click on the Rekordboxfolder setting and select the folder that the file above is located.
When the setting/path is changed, you will have to restart VirtualDJ to reload the RB database.
You have the Rekordbox folder under Local Music in VirtualDJ and no Playlists ?
If no Rekordbox folder at all, right-click on Local Music and see if there is an option to Show Rekordbox (was hidden)
geposted Tue 07 Feb 23 @ 12:43 pm
@DJDAD Thank you, it works now!!
Unfortunately, only manually created playlists are displayed, but not intelligent ones.
geposted Tue 07 Feb 23 @ 1:32 pm
Hello Dad
i found rekordbox
but every song have a red kross in
what must i do
thanks
i found rekordbox
what must i do
thanks
geposted Wed 08 Feb 23 @ 9:00 pm
