Hello I own the DDJ SR2 and i use it with vdj8 pro, and already noticed that the hot cue colors turn blank after a while. When you delete hot cues on the pads it of course deletes the colors but this is happening with out deleting any hot cues, the hot cues are still present just not showing up on the pads. Yet the hot cues are still present and of course where never deleted. Please let the techs know to fix as soon as possible because this can become a nuisance with other djs because you can get easily confused if you have hot cues or not. I know you can just look up at the monitor but I am sure you can understand thats just a temporary answer thanks.
geposted Fri 03 Mar 23 @ 8:33 am
