I have just bought 2 stanton T80s and hooked them up to a mixer
This mixer is an old kam made 2 fade . Ive put the leads into both phono and line inputs on the mixer but nothing registers. I have switched the phono line switch at the back of the turntables but still nothing registers. Noise is coming from the deck itself its just not going into the mixer. Have i got the wrong mixer? I assumed that any mixer with line in/ phono inputs would work, it has been about 25years since i last had decks so maybe something has changed?
geposted Fri 03 Mar 23 @ 1:43 pm
kam made to fade, did you get it out of a museum?
All I'm hearing is a lot of questions about analogue gear and nothing related to vdj software.
A mixer that old, used turntables, knackered cables, used needles. It's a process of testing 1 bit at a time.
geposted Fri 03 Mar 23 @ 1:51 pm
geposted Fri 03 Mar 23 @ 9:21 pm
