I am setting up a series of filter folders. Is there a priority to the order in which you add the query parameters i.e. should I pick out the bpm range before telling it to look for 2 or 3 different genres.
should you put all your "and" statement before the "or" statements etc. I may be making it more difficult than it should be but that's me all over. TIA.
geposted Fri 24 Mar 23 @ 8:29 pm
brackets are your friends too
( genre contains thing or genre contains "other thing" ) and bpm is > 125 and bpm is < 132
not sure about range but as as a matter of course I'd include it last
geposted Fri 24 Mar 23 @ 9:01 pm
Thank you. Got it sorted. I am still learning the power that VDJ gives you over your database. 👍
geposted Mon 27 Mar 23 @ 12:53 am
