My Reloop Ready is only recognized by the Windows version of VDJ 2023 as Midi-Controller when the ASIO-Drivers are installed. Without ASIO only as Audio-Interface without Midi working. On Mac it's detected as Midi and Audio. Is this behaviour normal or a bug?
There is also a remarkable delay of the sliders and knobs between the Reloop Ready and the skin.
geposted Mon 03 Apr 23 @ 11:23 am
Download and install the asio driver from reloop
https://www.reloop.com/downloadfinder
geposted Mon 03 Apr 23 @ 12:53 pm
Some MIDI controllers indeed require Windows Drivers to be installed for MIDI to work.
@DJDad thank you for clearifying. It's no problem to install the necessary drivers. I thougt midi needs no drivers as in MacOS.
geposted Mon 03 Apr 23 @ 3:58 pm
al reproducir un video en mi monitor, el video se mira con perfectos colores, pero al maximizarlo para que se llene la pantalla, un tono azul invade todos los colores, tambien cuando maximixo el virtual dj en mi monitor, los colores azules invaden el programa
geposted Wed 14 Aug 24 @ 5:50 am
