…on my Numark NVII (and neither without controller)
Problem: I have the stem controls set to using all 5 fader knobs per deck for stems control (Gain>Instru, Treble>HiHats, Mids>Vocal, Bass>Kick and Filter>Bass). On my NVII the first 4 work perfectly, but the filter knob keeps working as Filter instead of controlling the bass stem. This holds true both for the original skin as for the one I use, also if I dont use the NVII but just the VDJ screen
Probably just a simple settings problem? Anybody can help?
TIA, Rattler
TIA, Rattler
geposted Sun 07 May 23 @ 12:54 pm
Should be fixed in Early Access release 7553
https://www.virtualdj.com/download/build.html
geposted Sun 07 May 23 @ 2:28 pm
I am on Mac, VDJ v2023-gl b7544 and haven´t been updated since. Will follow your link and check
Thx, Rattler
Thx, Rattler
geposted Sun 07 May 23 @ 3:44 pm
Worked like a charm, thx!
Rattler
geposted Sun 07 May 23 @ 4:06 pm
