Hi,
I use Virtual DJ since many years.
2 months, I started to have issues with the Star Rating for Deezer musics.
The star rating disapear when I restart VirtualDJ, only for Deezer tracks. When I put new star rating they are sometimes not saved.
XML file: I went in the database.xml file. Here is an example.
<Song FilePath="netsearch://dz65444691" Flag="768">
<Tags Author="Robin Thicke" Title="Blurred Lines" Album="Blurred Lines" Flag="1" />
<Infos SongLength="263.0" FirstSeen="1679898128" />
<Link NetSearch="dz65444691" Cover="https://e-cdns-images.dzcdn.net/images/cover/6d81790a5a8e098fbe46ba17ecf79e30/500x500-000000-80-0-0.jpg" />
</Song>
It is supposed to have a Stars="5" since it is a very good track but there is no information.
Impact: many days of track rating are loss and I am sometimes unable to rate the tracks again, as this is specific to the audience I mix for.
The star rating (from zero to 5) for musics stored on my laptop on the C drive work fine: they don't disappear.
PS: When I start VirtualDJ, there is no issue to connect to Deezer account.
PS: I can send a version of the XML file if it helps.
PS: If you have a way to merge 2 database.xml file, and keep the star rating when filled, I would appreciate to have that tool. In fact, keeping the star rating is important for each track.
Version : VirtualDJ 2023 pc64 build 7482.1932
Please, your help would be appreciated
Please, did you have a similar issue before (even with another music provider) and how did you solve it ?
Thank you very much
Regards
Eddy
</Song>
Thank you very much
Regards
Eddy
geposted Sun 07 May 23 @ 6:09 pm
Hi,
please, what is your general feedback about VDJ and Deezer ?
Did you have a similar issue ?
Thank you
Regards
Eddy
Thank you
Regards
Eddy
geposted Mon 08 May 23 @ 5:36 pm
