Hi QA
Raising a ticket for a bug:
When switching from Frequency to 5 Knobs (Stems), Deck Colorfx FIlter still remains on; so turning Bass does not give the intended result of increasing or decreasing the stem.
Additionally, I'm unable to apply a toggle function to activate/de-activate deck colorfx to a h/w button?
e.g. Filter
e.g. Filter
geposted Sun 07 May 23 @ 10:23 pm
I've just tested it running latest early access build 7553
My test:
1. Use regular freq + gain + filter
2. Switch to "Stems (full mashup control using 5 knobs)" in the pop-up screen behind the dropdown
3. Use the filter knob
... and that then controls the bass stem
So if i understand you correctly it seems to work ok on my setup
My test:
geposted Mon 08 May 23 @ 12:32 am
Went back and checked the change logs for the latest release that I'm using, and there is indeed an entry saying:
"Fix filter knob in 5-stem eq mode still applying filter as well"
So if that could be the issue you are talking about, it seems to have been fixed in build 7553
geposted Mon 08 May 23 @ 12:34 am
Thanks for checking. For some reason thew latest update that I'm getting is:
VirtualDJ 2023 pc64 7544.1957
It appears to be present here. How do I get 7553?
geposted Tue 09 May 23 @ 6:53 pm
Currently 7544 is the latest "Standard" release of VDJ.
To get the "Early Access" build, (currently 7555) either,
1) change your settings option: earlyAccessUpdates to YES
(and restart VDJ)
or
2) download it directly from here:
https://www.virtualdj.com/download/build.html
This thread may be of interest:
https://www.virtualdj.com/forums/252454/VirtualDJ_Technical_Support/Stem_control_knobs_not_working_as_expected___.html
(and restart VDJ)
or
geposted Tue 09 May 23 @ 9:12 pm
