I recently got a pioneer rev 1 I plugged the mic into the controller and the mic is working fine but it's not showing on the sound meter of the program or recording I've been trying different settings in virtual DJ to get it to record but its not recording anyone know why It's not recording
geposted Sat 13 May 23 @ 9:55 pm
I didn't 100% know why (but suspected) but then I checked the manual https://www.virtualdj.com/manuals/hardware/pioneer/ddjrev1/layout/frontrear.html
geposted Sat 13 May 23 @ 10:42 pm
The Mic input of the REV1 should be recorded along with your mix if your Audio setup is as per the default one.. https://www.virtualdj.com/manuals/hardware/pioneer/ddjrev1/installation.html (the "record" input is set to Chans 1,2 of the REV1 audio device)
geposted Sun 14 May 23 @ 6:35 am
I set it up according to the manual but It has input record and then the middle box Is empty where it should have ddj rev 1 then It has chan1,2 before it was recording the music but not the mic but now its not recording the mic or the music anyone know why ! also the small box in the bottom right hand corner where It has the option ddj rev1 or config 1 Im not sure about this either because the manual doesn't show this box
geposted Sun 14 May 23 @ 9:45 pm
I just set up on my windows 10 computer all worked as it should mic and music recorded no problem but its not working on this new windows 11 computer anyone had problems running virtual DJ on windows 11
geposted Sun 14 May 23 @ 10:48 pm
