Topic: Pioneer DDJ-FLX4 controller
Hello, I have the Virtual Dj 2011 Pro Infinity version, how can I add the Pioneer DDJ-FLX4 console to it, it does not detect it at all, in the free version 2023 it works normally
geposted Thu 18 May 23 @ 12:15 pm
If it works normally in the latest version then why on earth would you be trying to use it with a version from 2011, when the FLX4 didn't exist?
Use it with the latest version, and buy a license!
You probably mean VDJ2021, which is correct - that version is from before the FLX4 controller was released and supported
Looking at the changelog, the FLX was supported from CDJ 2023 BUILD 7445 which was released in mid February this year
2 more things
- The free version and the pro infinity version is the same - it all depends on the licenses attached to the credentials you use when you login to the software
- You do need a license for it to work for more than a 10 min test period. As soon as you get a license it will be attached to your current credentials (that you have used to write this post), and when you then login to your "free version" that works with the FLX4, it will become the pro version
