In Rekordbox or on a CDJ - if you're in a loop then the Beat Jump distance is relative to the start of the loop, not the current position in the loop. Is there any solution for VirtualDJ to behave this way?
geposted Wed 07 Jun 23 @ 6:15 am
just wanted to ask the same question. the beat jump does not the same to the beginning of the loop as it does with the end.
shift + jog in a loop had similar issues but it got fixed recently. now it will always move the loop when reaching the beginning or end of it.
geposted Sun 11 Jun 23 @ 3:46 pm
issue exists for "goto" and "beatjump"
geposted Sun 11 Jun 23 @ 3:55 pm
