Topic: Did recent automix fix break gap?
Automix issues:
1) I tried using Fade (remove silence) with a -2 second overlap - i.e. a 2S gap configured
But when it plays - almost no gap. As soon as the first track ends, the next track starts. If I make the gap 4s, then I do get a gap, but it's about 2.5 seconds. Not sure what's going on here? I guess not many people want the dead gap between tracks, but for me it would be a necessity.
2) In Single Deck mode, it often ignores the Automix cues and starts the next track from the beginning. Yes - I'm using the right cue for the Automix - heck to keep things simple I often have both FULL and FADE in the same place, but no - track still starts at the beginning. In DUAL deck mode note, it works just fine.
3) The Fade out, cut in option is missing from the screen, although it's available in settings.
NB (Ignore the title which I can't amend - thought my VDJ had updated, but nope - still using the version I downloaded a month ago.
geposted Fri 16 Jun 23 @ 8:59 pm
