Topic: EQ Knöpfe bleiben stehen
Die Eq Knöpfe drehen manches mal nicht mit bzw bleiben stehen !
geposted Mon 19 Jun 23 @ 8:06 am
More info needed
On the screen?
On a controller? if so - which controller?
(Some controllers and mixers work in pure hardware mode, so you can't see on the screen when the eq moves/changes)
geposted Mon 19 Jun 23 @ 8:27 am
Hello, I am using the new Pioneer DDJ FLX 10, I think the problem is with the software! The rules always stop there, so I always have to tighten them, e.g. during transition (I only felt it after the last 3 updates) before that everything worked great! Kind regards, Toby
geposted Mon 19 Jun 23 @ 11:15 am
