Topic: nvidia card settings for stems
should i have my driver settings on my rtx 4070 set to "quality" or "performance". if it even matters. in the sim games i play. i prefer quality. but if performance is better. then before a set ill just switch
geposted Tue 20 Jun 23 @ 8:23 am
I found there was no difference on the 4080. None of the settings affected VDJ or the stems calculation times in any meaningful way.
I have the 3060 and found the same, made no difference to VDJ, so would say just leave it as standard.
ok thanks.
For sim games, it's generally preferable to prioritize "quality" settings on your RTX 4070 driver settings.
