lets say i have 25 folder with 100 songs
and im not sure folder 19 is analyzed. if i do it again. will it just renalyze. or create duplicates? (in the database)
geposted Thu 06 Jul 23 @ 8:56 am
Analyzing will only process the files already there. You need to do add to database and it won't create duplicates.
geposted Thu 06 Jul 23 @ 9:09 am
oh. so after i analyze for bpm, etc. when done. and the folders to the search database too. as the next step?
i thought analyzing added them to the search database already. oops.
geposted Thu 06 Jul 23 @ 9:15 am
Add to DB first then analyze. You can't analyze something that's not there.
geposted Thu 06 Jul 23 @ 9:42 am
lol all these years and just re analyzed. and never added to db. the way i mix is using the last folder so no need to search. now i want to search. and see why i cant. derp on me. :)
geposted Thu 06 Jul 23 @ 2:51 pm
Maybe you'd benefit from reading the manual to see how database management works.
geposted Thu 06 Jul 23 @ 2:58 pm
i installed vdj 15 years ago before that was cool :) anyway am reading the section about creating filter folders.
geposted Thu 06 Jul 23 @ 3:06 pm
By default autoSearchDb is enabled, so any folder that you browse would also be in the search db, and there would indeed be no need to manually add files that you see to the search db.
Only if you have autoSearchDb disabled you would indeed need to add them to the search db manually, but you are free to do it before or after analyzing.
geposted Thu 06 Jul 23 @ 3:08 pm
