I'm trying to test a Hercules Inpulse 200 for 10 minutes like all the documentation says, but nothing seems to work.
I know the controller works, I tested it fine in Mixxx. It even detects the button presses in the mapping page of the settings, but nothing actually works. How do I enabled the 10 minute test in Virtual DJ?
geposted Sat 08 Jul 23 @ 4:00 am
If it's the Mk2 then it's not supported yet.
geposted Sat 08 Jul 23 @ 7:30 am
Then how come this page says it is?
https://www.virtualdj.com/manuals/hardware/hercules/inpulse200mk2/setup.html
geposted Mon 10 Jul 23 @ 12:34 pm
Support was released after I posted that.
geposted Mon 10 Jul 23 @ 12:43 pm
Indeed , support for Inpulse 200MK2 has been just added to Build 7555 (or later)
You may have to restart VirtualDJ twice (silent update of Controllers patch)
geposted Mon 10 Jul 23 @ 1:40 pm
Looks like it's up and working now, yes. Thanks for the replies!
geposted Tue 11 Jul 23 @ 2:07 pm
