I have a 9900kf right now and I was looking at the i7 13700k and was wondering what would be better a new cpu or a upgrade from my rtx 2070 for vdj and streaming
geposted Tue 11 Jul 23 @ 7:37 am
My vote would be .. a faster GPU would be the choice.
You can use Task Manager .. and check what resource is your bottleneck.
(which component is being used the most, or at its max)
My guess again, is it's the GPU.. especially if you are wanting 2.0 stems.
Others may also have advice.
geposted Tue 11 Jul 23 @ 8:59 am
link at the top of this tech support page
https://www.virtualdj.com/forums/249163/VirtualDJ_Technical_Support/VirtualDJ_2023___Stems_2_0_-_FAQ.html
but a RTX 3050 or better is what you're looking for.
geposted Tue 11 Jul 23 @ 10:19 am
Since you already have an RTX 2070, what performance issue do you have exactly that you want to solve?
geposted Tue 11 Jul 23 @ 10:43 am
I lag when I stream
geposted Tue 11 Jul 23 @ 2:50 pm
wildcountryclub wrote :
ty 😊 link at the top of this tech support page
geposted Tue 11 Jul 23 @ 2:51 pm
