Hi,
I'm wondering if that is a feature or a bug. Can't say if it was different in older versions.
When I use the browser on the touch screen of my Prime GO controller. The selected song (by a finger press) loads directly to a free deck. If no free deck is available, it load to the deck that is not master.
I think that is the behavior of a double mouse click on the laptop.
I think it didn't happen before, since my normal workflow is:
1) Open browser
2) Start preview
3) Select songs from the list, so I can prelisten to them, until I find a song to load.
4) Load the song
What is not possible any more with this feature/bug
5) Search a possible alternative song, while the first choice stays in deck if no alternative is found.
Is this a bug or a feature? I don't beleve that is has been like that all the time.
1) Open browser
2) Start preview
4) Load the song
geposted Fri 21 Jul 23 @ 11:35 am
Dont quite recall the exact name of the setting -not near to a computer - but check OPTIONS tab of VirtualDJ Settings and search for "finger".
Could be twofingersscroll or something similar
geposted Fri 21 Jul 23 @ 6:06 pm
Sorry, no, this isn't it
geposted Sat 22 Jul 23 @ 4:23 am
Hey DJ Dad,
thx for the fast reply, but the twoFingerScroll option does not affect the described behavior.
But I found that everything was working fine with build 7555.
With build 7607 the bug occurs.
So something between these versions changed something resulting in that bug.
I could do a video of it, if that would help.
Would be nice if somebody could have a look into it.
Thx and have a nice weekend
Jochen
Jochen
geposted Sat 22 Jul 23 @ 7:12 am
i saw this in the changelogs:
BUILD 7584 (2023-06-11)
-Fix double-click in search_playlists window not selecting file in browser
Could this Fix have been the thing that broke the track select for us on prime 4 touchscreens?
geposted Mon 24 Jul 23 @ 4:49 am
No, but we are investigating the issue right now.
geposted Mon 24 Jul 23 @ 8:46 am
Issue is fixed in Build 7611, which is currently in Early Access, so you need to enable EarlyAccessUpdates setting from VirtualDJ Settings->OPTIONS tab and restart VirtualDJ.
geposted Sun 30 Jul 23 @ 6:05 pm
Thank you! On a sunday evening? When do you guys take a rest? You are awesome!
That's why I love VDJ ❤️
geposted Sun 30 Jul 23 @ 6:22 pm
I will co-sign that the screen touch behavior has reverted to the expected behavior on b7612
geposted Mon 31 Jul 23 @ 3:11 am
