Hello,
I have just a little question. I Use a Numark DJ2GO controller with Numark Cue (same as virtual DJ) version 7.4.7. Sometimes i use the automix function. Is there a way to indicate with one of the LED's on the controller, let me say a flashing PFL LED or so, to tell me that the automix function is on? If so, how to setup? Thank you!
geposted Tue 25 Jul 23 @ 8:53 pm
i have no idea... i just know support for 7 was ended a while ago and that it's long past time to update to the current software.
geposted Tue 25 Jul 23 @ 8:54 pm
