Hello all,
I've been at this for over a day now so asking for help. I'm trying to set my performance pads to blink while stems filtering is active, as the dimmed LED on my controller is still very bright and hard to tell if it's on or not. I've gotten pretty close with pad_pushed and some others, but it only turns off the LED while the pad is held. Any help is much appreciated!
geposted Wed 26 Jul 23 @ 12:14 am
Assuming that you try to edit the Stems pad page from Pad Page Editor,
1) Click on push action and copy the action. For the first pad it should be stem_pad 'vocal'
2) Click on color, uncheck "Auto Dim"
3) Modify the color as follows: stem_pad 'vocal' ? blink ? color 'blue' : color 50% blue : color 'blue'
Repeat for the rest pads
PS: You may also want to try to use different percentages for the dimmed state like color 30% 'blue'
It depends on the controller whether or not it will have a good color.
geposted Wed 26 Jul 23 @ 12:21 am
