Topic: Automatic stem 2.0 create when loading track
MC242PRO InfinityMember since 2017
Hallo, I have the following question:
Is it possible with VDJ to automatically create a stem 2.0 version of a track on the fly when it is loaded onto a deck, or is it always necessary to first prepare the stems?
Cheers
geposted Sun 30 Jul 23 @ 10:08 am
Yes assuming your machine is powerful enough to process the stems.
geposted Sun 30 Jul 23 @ 11:27 am
Thank you for the answer, Kradcliffe.
I have just recently got my hands on a 2023 MacBook Pro with M2 Pro processor and 32 GB Ram, so I guess it is definitely powerful enough.
Could you explain what I have to do in order to have VDJ create the stems automatically?
Cheers
geposted Mon 31 Jul 23 @ 4:20 am
Default settings should do it already, but if not, simply set stemsRealtimeSeparation to Always
geposted Mon 31 Jul 23 @ 4:37 am
Ah okay, thank you! This option is already activated.
I thought I had to activate something else.
Quality with stems is already pretty good. But I thought it could be even better.
Anyway, thanks for your help!
geposted Tue 01 Aug 23 @ 11:19 am
