Is it possible to generate playlists from multiple filterfolders at once. I want to regularly create playlists from all my filterfolders, but clicking each one separately to create a playlist is a bit time consuming.
geposted Sat 05 Aug 23 @ 5:44 pm
shift click the filters
geposted Sat 05 Aug 23 @ 5:48 pm
What does shift click do? Nothing seems to happen? :-)
geposted Thu 10 Aug 23 @ 2:47 pm
adds all files from filters/folder to songs section, from there you can select all and make your playlist.
geposted Thu 10 Aug 23 @ 2:59 pm
Sorry to ask, but what is the song section?
geposted Thu 10 Aug 23 @ 4:38 pm
..and then VDJ freezes for a minute and crashes.
W10, fully updated, b7617
geposted Fri 11 Aug 23 @ 8:58 am
Hi, that's not what I meant. I mean if you have for example 5 filterfolders, that with one click you have five you can generate 5 playlists.
geposted Sun 13 Aug 23 @ 3:48 pm
