I have a clap loop that I would like to trigger from any deck's pad (DDJ-1000) or Pioneer DDJ-XP2 pads and I would like this loop to sync with the track playing on the Master deck.
When I trigger this sample on the Master deck using this deck's pads, the clip is in sync.
When I trigger this sample from any other deck's pad, the clip is out of sync.
The official word is "You need to trigger the sample from the sampler directly in the side view in order to sync to the master deck." but I think this is a serious limitation - I want to use controller pads rather than mouse on my laptop.
Does anyone know how to configure the sampler loop so it's sync'ed from any deck?
Here's my loop
![](/img/387959/79789/2023-08-09 15_30_02-Window.png)
This is how it is configured
![](/img/387960/45343/2023-08-09 15_32_12-Window.png)
![](/img/387961/56045/2023-08-09 15_33_20-Window.png)
Any suggestions would be greatly appreciated!!
Here's my loop
geposted Wed 09 Aug 23 @ 10:35 pm
a padpage sample pad call takes it's sync from the deck it was called from.
I wasn't a fan of that idea either. For me a sampler call shouldn't matter from where, it should always sync master.
So I did this
change your sampler padpage scripts from
sampler_pad 1
to
deck master sampler_pad 1
then it doesn't matter which deck the padpage is on.
So I did this
sampler_pad 1
to
geposted Wed 09 Aug 23 @ 11:06 pm
@LOCODOG thank you so much for sharing your solution!
Would you please share a little more detail on where to find these sampler padpage scripts.
I've searched my controller mapping, and the only place I've found sampler_pad1 is showing in the screenshot below, and it's mapped to pad 1.
This doesn't quite look like the script you're showing.
Do I need to create these scripts from scratch? or is this the right place?
![](/img/388004/23932/2023-08-10 10_00_10.png)
Would appreciate any help on this!
geposted Thu 10 Aug 23 @ 5:13 pm
not the controller mapping, I mean edit the padpage.
geposted Thu 10 Aug 23 @ 5:30 pm
My sampler pads are set to sampler_pad 1 "auto"
Should I preserve "auto"?
deck master sampler_pad 1 "auto"
![](/img/388011/81271/2023-08-10 10_55_07-VirtualDJ.png)
geposted Thu 10 Aug 23 @ 5:57 pm
erm, yeah. I got rid of the 'auto' for my own reasons.
geposted Thu 10 Aug 23 @ 6:03 pm
This solution worked beautifully using either my controller or DDJ-XP2 pads any deck.
Should be the default for any samples configured to Sync-Start or Sync-Lock...
Thanks again @LOCODOG!
geposted Fri 11 Aug 23 @ 12:22 am
